KilnRed;334 wrote:
You can say that again. I've just recently developed one on my car. Haven't had the time to chase it down yet. That's the bad part of using the 928 as a daily driver, but hey, I have no other options 'til I rebuild the engine in my truck. Though the drain is only about 86 hundredths of an amp, if ignored, it will definitely kill the battery.
For now, I'm just disconnecting the battery by way of the wing nut on the battery ground strap when I know I'm not going to be driving for a little while.
Ya guys, 350 milliamps will kill the battery in a week so 850 ml is way to much.
The way to check is to disable the passenger side door switch by unplugging it so that you can pull fuses when you get a meter hooked up. set your meter on amps and plug the positive probe at the meter into its 10 amp hole. Disconnect the negative cable and hook the leads between the cable and the battery. read the draw and start pulling fuses until you find the circuit that kills the draw. That will give you a direction to go
