TOPIC: Dash cluster light stays on after key removed
Dash cluster light stays on after key removed 15 Jan 2010 17:21 #69
  • 928mac's Avatar
  • 928mac
Before I put the car away this fall I noticed that the battery was going dead.
So when I would put it in the garage I would stick the trickle charger on it thinking that it could possible be a diode leaking in the alternator. (I thought this because it wasn't ever charging as high as it should)
One day when I walked up to go for a drive, before I opened the door I saw the dash cluster information center was on.
Ah Ha! thats what keeps draining the battery.
After a while of checking all switches for off, I put the key in the door and locked it.
The dash went out.
Some times it will come back on after a while but I am not sure if it dose due to a low voltage situation. :confused:
I never confirmed any of this yet
Also as a question;
The display is in german.
I don't read german :rolleyes:
Any one know how it is set to english
Also ha ha is there a scan tool connection on the 89 928 S4
I have been a GM tech for 18 years
but you still only know what your taught or what you have info on
Thanks to all that leave a reply
Maybe I can help with north american questions :eek: if sent to my e-mail at
This email address is being protected from spambots. You need JavaScript enabled to view it.
Dash cluster light stays on after key removed 15 Jan 2010 20:47 #71
  • adminVB's Avatar
  • adminVB
I would suggest reviewing http://www.jdsporsche.com/ and http://jenniskens.livedsl.nl/diag/Diag.htm both might have offerings. One of the 928 vendors might sell them in the United Stateds.
The 928 Owners Club has the Jenniskens 928 Diag Tool, and it is lent out to event coordinators when events are held. Maybe a good reason for you to consider organizing an event :)
Dash cluster light stays on after key removed 17 Jan 2010 01:55 #72
  • 928mac's Avatar
  • 928mac
Thanks for the Jenniskens link, admin. the other one dose not relate to any of the above though but thanks. This is not a very active forum eh
Dash cluster light stays on after key removed 18 Jan 2010 09:18 #73
  • adminVB's Avatar
  • adminVB
Correct, although it is new, the old forum was not too active either. Members are too busy enjoying their 928s perhaps :)
Dash cluster light stays on after key removed 21 Jan 2010 00:29 #74
  • 928mac's Avatar
  • 928mac
Ha Ha oh now thats just mean since its winter here and I get to just look at mine each day.
BTW I found the diagrams for the fuse box in the manuals at the link below
My first step so that I can do a parasitic draw test while removing fuses to find the circuit that has the drain, incase there is more then one issue.
http://www.cannell.co.uk/Manuals.htm
Dash cluster light stays on after key removed 23 Jan 2010 13:20 #77
  • Kiln_Red's Avatar
  • Kiln_Red
A little snow and ice hasn't always stopped me from getting my car out for a spin. No pun intended. I just keep my 28 on country roads and away from other traffic. :cool:
Dash cluster light stays on after key removed 23 Jan 2010 14:15 #78
  • adminVB's Avatar
  • adminVB
Probably a bit different from Alberta to TN :)
Here in MA, the salt/de-icer they put on the road is enough for me to hesitate about driving my fun cars :eek:
Dash cluster light stays on after key removed 24 Jan 2010 00:12 #80
  • 928mac's Avatar
  • 928mac
Ya know dought. I don't think I want any salt on an old car. I am guessing that mine is still original and even though I am thinking of taking it in for paint, I am hesitating about that. There are also so points that are not aluminum and the salt will cause that nice white oxidation. Has the Admin posted any car Pics. It is always nice to view other peoples cars and get ideas. Hint Hint
Dash cluster light stays on after key removed 24 Jan 2010 06:36 #81
  • adminVB's Avatar
  • adminVB
Just a couple of small ones I had laying about in my profile topic at http://forums.928oc.org/vbulletin/showthread.php?t=22
Dash cluster light stays on after key removed 25 Jan 2010 13:23 #82
  • Kiln_Red's Avatar
  • Kiln_Red
That's another reason why I said country roads. In Tennessee, our country roads don't get conditioned the same way as our main roads with salt and such. I love it!! :D
Time to create page: 0.181 seconds
