TOPIC: Problem with engine do a flex plate.
Problem with engine do a flex plate. 02 Jun 2020 05:12 #21250
  • Christian's Avatar
  • Christian
  • New Forum Member
Hello.
I am new on this forum.
I have an engine problem problem with my 928 S4 automatic do a flex plate failure. My mechanic saids the all engine needs to be remplaced for a certified rebuild one. I have been going though the web and I have found rebuild kits, but I am looking for the coplete engine. Here is my question, Does any of you know where I can buy a certified rebuild engine?. I am in Spain so I would like to know any workshop in Europe prferably to look for. But if there isn't I would consider to buy in the States.
Thanks in advance.
Best regards to every one on this forum.
Problem with engine do a flex plate. 11 Jun 2020 06:59 #21277
  • Posts:309 Thank you received: 18
  • Rich928's Avatar
  • Rich928
Hello Christian,
Welcome and sorry to hear of your problem. I am not aware of any company, perhaps other than Porsche, that keeps a new or completely rebuilt Porsche 928 engine in stock ready to ship. The best solution would be to source a good used engine and have a mechanic perform a complete rebuild. Here in the USA companies like 928 International have complete used 928 engines in stock.
For those who may not be aware of what I think the problem is. Here it is described as due to the flex plate, but I believe it is the thrust bearing failed due to pressure from the flex plate.
I wrote an article about releasing the pressure on the flex plate, see the attachment.
This is a periodic maintenance issue that I recommend on 1985 and newer Porsche 928s equipped with automatic transmissions.
The following user(s) said Thank You: Christian
Problem with engine do a flex plate. 16 Jun 2020 04:08 #21288
  • Christian
  • New Forum Member
Thank you very much for your help, it's very mych appreciated..
Regards.
Time to create page: 0.152 seconds
