TOPIC: Air Intakes Tubes
Air Intakes Tubes 25 Mar 2018 14:19 #20272
  • Posts:15 Thank you received: 1
  • mrgrinch2000's Avatar
  • mrgrinch2000
Has anyone found a replacement for the OEM plastic air intake tubes?.
Looking at replacing both of mine.
With the cost exceeding $500 for both I thought I would check to see if anyone had found a cheaper yet better alternative?.
Thanks for the read.
Mr Grinch
Air Intakes Tubes 08 Apr 2018 21:31 #20286
  • mrgrinch2000
110 views....and no input or advice...not even an atta boy.
Thanks for the help.
Everyone can stand down......I have found a solution.
Mrgrinch
Air Intakes Tubes 02 May 2018 22:52 #20325
  • Randolator's Avatar
  • Randolator
  • New Forum Member
What I've done is wrapped my intake tubes in aluminum-coated bubble wrap and metal tape. It seals them up and insulates them from the high engine temperatures and makes the running temperature of the engine drop significantly. Sounds kludgy but it really works!!
Air Intakes Tubes 14 May 2018 13:32 #20362
  • Posts:1108 Thank you received: 25
  • martinss's Avatar
  • martinss
  • Platinum Forum Member
I think most people endeavour to keep stock, which is likely why you did not get a reply. On my '88 I found that standard aftermarket air tubes and junctions can be adapted:
I totally would not go with Red if I did it again - black is readily available. The price is a tiny fraction of OE.
Last Edit: 14 May 2018 13:32 by martinss.
Air Intakes Tubes 01 Sep 2018 20:22 #20583
  • Fronkenstein's Avatar
  • Fronkenstein
Aluminum bendable dryer vent tubing :)
Air Intakes Tubes 03 Sep 2018 21:50 #20590
  • Posts:301 Thank you received: 18
  • Rich928's Avatar
  • Rich928
Mercedes Benz hose part number
117-094-03-82 tubes will fit. You'll need two per side (total of four).
The following user(s) said Thank You: jWs, hey_allen
Air Intakes Tubes 14 Sep 2018 15:11 #20595
  • hey_allen's Avatar
  • hey_allen
  • New Forum Member
I had to finally sign up after stumbling across a link to this forum, and seeing this thread.
I just started working of fixing a 1978 928 that I was given, after objecting to a friend planning on scrapping it for the aluminum and copper.
There are numerous things broken or missing after years of neglect, but one of the things that bugged me the most, was just the visual impact of the intake tubes being missing, and how incomplete it looks under the hood, with them not present.
I think I'll have to model and 3d print a coupler to connect the tubes, and to tie into the timing belt vents, but having the tubes easily available makes it feasible.
Time to create page: 0.166 seconds
