On the above vehicle, I had the A/C compressor change, the system O-rings, and the Freon filter as well. However, the air from the front vent is still not cold as it was originally.
The system was also converted from R-12? Freon to R134A? Freon.
The shop says the issue may be the front evaporator and suspects its clogged and not allow full free flow. At high RPMs the A/C gets cold but previous, I could not set A/C to lowest setting in mid-summer as I would freeze.
Any ideas? Is there anything else to consider that might be an issue besides the evaporator? What is a reasonable cost for the evaporator? And replacement?
Thank you!
Darrell
