TOPIC: 1987 oil filter brand/color
1987 oil filter brand/color 12 Jun 2016 14:03 #19063
  • Posts:35 Thank you received: 1
  • S4George's Avatar
  • S4George
What brand of oil filter did Porsche use for MY 87 when they rolled out? Also, were they Black or Red?
1987 oil filter brand/color 16 Jun 2016 21:05 #19067
  • Posts:122 Thank you received: 10
  • jmwise's Avatar
  • jmwise
  • Senior Forum Member
  • NOW ONLINE
I can find no reference to the brand or color of oil filter originally fitted to your 87S4 in either the Owner's Manual, the Technical Specifications booklet (which goes into MUCH greater detail than the owner's manual) or PET. However, reliable sources have indicated it was a Purolator.
The good news, though, is Porsche Classic Genuine Parts has re-introduced the "original" oil filter, indeed a Purolator that is red in color. The current part number appears to be 928 107 201 07, although I've seen what's believed to be a truly original filter bearing 928 107 201 03. More info here: rennlist.com/forums/928-forum/844705-por...-red-oil-filter.html and here rennlist.com/forums/928-forum/378250-oil...nds-for-a-928-a.html
Should be available through Porsche Classic Genuine Parts channels, or just call Roger at 928sRUs (817) 430-2688
HTH!
Jarrod Wise
90GT
928 Owners Club President
928 Registry Chair
The following user(s) said Thank You: S4George
1987 oil filter brand/color 17 Jun 2016 14:49 #19069
  • S4George's Avatar
  • S4George
Thank you very much Jarrod. Huge help!
1987 oil filter brand/color 30 Jun 2016 14:59 #19095
  • Kiln_Red's Avatar
  • Kiln_Red
The original filter is a Mahle. Not sure what color they were then, bit the Mahle filters are all black for the 928.
Edit: Correction! The very first filter that came with your MY87 may have very well been a red Purolator, as Jarrod said.
Last Edit: 30 Jun 2016 15:15 by Kiln_Red.
1987 oil filter brand/color 01 Jul 2016 16:09 #19105
  • S4George's Avatar
  • S4George
Thanks KR. I went with a 92810720107
Time to create page: 1.307 seconds
