TOPIC: Directional Problem
Directional Problem 31 Oct 2009 18:56 #18
  • avanhelden's Avatar
  • avanhelden
When using the right directional there is a rapid flash on the front, and none at the rear. However, if the directional is left on and the car is turned off and the key removed, the right front light stays on, no flashing. Initially I thought is was a bad rear bulb but I checked it and it is good. Where do I start??
Directional Problem 31 Oct 2009 19:36 #19
  • adminVB's Avatar
  • adminVB
I believe all years have a separate fuse for each signal, so perhaps best to start there. 928 Specialists has fuse/relay layouts at their site, if you don't have a manual: http://928gt.com/
Directional Problem 01 Nov 2009 10:02 #21
  • avanhelden
Thanks for the feedback, I checked the fuses and all are good. With my limited electrical knowledge, since it is a constant light when ignition is off, I assume it must bypass the flasher, or would the flasher only work with the ignition on and thus give a constant light?
Directional Problem 01 Nov 2009 14:25 #23
  • adminVB's Avatar
  • adminVB
You could check Greg's site for tips too:
http://nichols.nu/cat02.htm
Directional Problem 03 Nov 2009 13:16 #24
  • Kiln_Red's Avatar
  • Kiln_Red
When you inspected the bulb itself to confirm that it was still good, did you check for voltage on the bulb's electrical socket? Since you said that all of the fuses check out fine I presume that either corrosion inside the socket's connections or a short is your culprit.
~ Austin
Directional Problem 04 Nov 2009 18:23 #25
  • avanhelden
Went back and checked for corrosion etc. then I went on and put an ohm meter on the bulb terminals to discover that the flashing, while the blinker is on, is reflected however the volt meter reads zero. Could the power going through the relay be interupted there?
Directional Problem 05 Nov 2009 12:46 #26
  • Kiln_Red's Avatar
  • Kiln_Red
It certainly isn't a power supply issue at the central electric board because if that were so, then neither signal would work. Since you found no voltage on the plug terminals, the most likely scenario is either a fault with one of the wires itself or a short. Your switch is obviously doing its job correctly since the front marker is working.
A high ohm value would further support my suspicion of a short. What was your reading?
Directional Problem 06 Nov 2009 13:23 #28
  • Kiln_Red's Avatar
  • Kiln_Red
Check fuse #33 again...
I had forgotten that each individual signal is fuse protected. Are you certain that its good?
Directional Problem 21 Nov 2009 21:02 #32
  • avanhelden
I want to thank all for the input, it all came down to poor conection at the fuse. Working great now. Now on to the wipers.
Time to create page: 0.157 seconds
