TOPIC: Does anyone know where the 12-pin passenger door connector is on a 1990 GT?
Does anyone know where the 12-pin passenger door connector is on a 1990 GT? 15 Oct 2012 10:37 #11846
  • Cu++er's Avatar
  • Cu++er
It is supposed to be the ultimate way to emergency bypass the switch and Window Control Unit by jumpering 12v power directly to the passenger door Window motor, via pins 1 and 2. This would sure beat the heck out of having to pull the door panel off to access the motor connections! I saw a reference that says it is down alongside the side firewall for each door, but I simply cannot find it.
On older 928s, it was an 18-pin connector. On 90 and above, it supposedly went to 12 pin.
Does anyone know where the 12-pin passenger door connector is on a 1990 GT? 15 Oct 2012 10:46 #11848
  • Kiln_Red's Avatar
  • Kiln_Red
Are you referring to the door plug that connects just above the fuel brain?
Does anyone know where the 12-pin passenger door connector is on a 1990 GT? 15 Oct 2012 10:53 #11849
  • Cu++er's Avatar
  • Cu++er
Not really sure? It is the one that feeds all the wires that go into the passenger door.
Does anyone know where the 12-pin passenger door connector is on a 1990 GT? 15 Oct 2012 14:30 #11850
  • Kiln_Red's Avatar
  • Kiln_Red
Yes, same plug.
Time to create page: 0.874 seconds
