TOPIC: Mystery Wire
Mystery Wire 17 Apr 2012 20:06 #8942
  • raidonzap's Avatar
  • raidonzap
Hi all,
Just getting ready for a MM; OPG; steering rack bushing job and came across this wire:
It is attached to the wire harness.
Any help would be great. Thanks.
Drew
Mystery Wire 17 Apr 2012 20:19 #8943
  • srshaw3's Avatar
  • srshaw3
  • Platinum Forum Member
I can't tell the gauge.
Is it a ground wire?
Are you saying it was disconnected already?
What are the wires nearby to?
Mystery Wire 17 Apr 2012 20:21 #8944
  • srshaw3's Avatar
  • srshaw3
What a minute, is that the top of the motor? Are those the cam cover breathers I see?
It has been a while, but the projects you listed are all *under* the car.... :confused:
Mystery Wire 17 Apr 2012 20:45 #8946
  • raidonzap
Thanks for the quick reply.
Yes, that's the top front right side of the engine, the wire is disconnected.
I have reviewed the ground diagram and haven't come across this one which is a heavy gage black wire. one end is attached to the clamp in the picture.
It is next to the jump post.
Thanks again and sorry for the confusion.
I have added to the crappy picture:
Mystery Wire 18 Apr 2012 10:01 #8953
  • raidonzap
Thanks Malcolm, I knew it was an easy one for the guru's, I just had a holy crap moment seeing it loose like that.
So the loose end will go to the coil, the other end is connected to the hall sensor bracket, I'll fix her up tonight.
I'm sure I'll have more issues to post here before too long that are more of a challenge. :p
Thanks!
Drew
Mystery Wire 21 Sep 2012 09:52 #11373
  • emmanuelli's Avatar
  • emmanuelli
  • Elite Forum Member
hey drew, any recent pics of your babe? i also have an 86 meteor gray metallic, 5spd. looking for some inspiration.
Mystery Wire 22 Sep 2012 08:28 #11403
  • Kiln_Red's Avatar
  • Kiln_Red
Wow. That looks familiar. Looks like the same ground wire that was left dangling on my '85 when I first acquired it. In my case, I just grounded it to the valve cover or some other close by area. Can't recall completely. My car had had the engine out of it just prior to when I bought it. Was the engine removed from your car? Maybe, in both cases, that wire was forgotten and not replaced.
Mystery Wire 24 Sep 2012 20:02 #11432
  • rluvsporsche's Avatar
  • rluvsporsche
That appears to be ground that attaches to ignition coil mounting and the other end to engine lift hook next to the valve covers.
Time to create page: 0.552 seconds
